Sharing a route via Bluetooth
wingrider.steve
Post by wingrider.steve »
I've been trying to share a route from my XT to a zumo 396 without success.
Followed the Garmin procedure but cannot get the route to transfer from the XT to the 396, is there some trick to it?
XIKO29
Portugal
Re: Sharing a route via Bluetooth
Post by XIKO29 »
Restart both devices and try again.
wingrider.steve
Yeah, tried that, it made no difference.
XIKO29
Portugal
Post by XIKO29 »
wingrider.steve wrote:Yeah, tried that, it made no difference.
Sorry, but i never tried.
What i said was what i saw on a Dutch Garmin Facebook group.
If you have Twitter, ask Garmin. They usually answer.
yorky
Been liked: 16 times
Post by yorky »
I know this reply is no help but I tried numerous times last week to transfer from my XT to a mates 590, never managed to get it to work!
wingrider.steve
XIKO29 wrote: Wed Aug 05, 2020 4:49 pm Restart both devices and try again.
I did try switching off both devices and then back on but it made no difference. I just tried doing a hard reset on both Zumos and that did the trick!
I've now successfully shared several routes between the two devices without any problems.
Has liked: 381 times
Been liked: 384 times
Worth saying that after a software update a master reset is advisable, and definitely if you're experiencing any issues
XIKO29
Portugal
Post by XIKO29 »
sussamb wrote:Worth saying that after a software update a master reset is advisable, and definitely if you're experiencing any issues
How do you do a master reset on the XT?
Can't say for sure, sorry, but this guide should help http://www.poi-factory.com/node/30019
wingrider.steve
Press and hold the power switch in until the unit restarts.
