Photo upload
Need help with the forum? or got some forum feedback? Please use this section.
MotoToph
Has liked: 28 times
Been liked: 14 times
Photo upload
Post by MotoToph »
What are you all using for image hosting? I tried using imgbb but the forum doesn't recognize it for some reason.
ZUMO XT
K1600GT
Has liked: 414 times
Been liked: 229 times
Re: Photo upload
You can upload straight to the forum no need to use a third party
Re: Photo upload
I have done a how to here viewtopic.php?f=22&t=966 :)
MotoToph
Has liked: 28 times
Re: Photo upload
Post by MotoToph »
I'm sorry, I should've been more specific. I am trying to add a signature photo. I did not see anything for attachments there.
ZUMO XT
K1600GT
Re: Photo upload
Ah yes signatures require external hosting!
Although imgbb should still work all I will say is go careful of the size as signature images can turn out huge!
Try the code again and I will have a look at it once its in your signature and see whats going on :)
Has liked: 117 times
Been liked: 348 times
Re: Photo upload
I know I am two years late but as a imgbb user I thought I would post that when inserting an image hosted on imgbb you need to use their Direct Link embed code url.
Re: Photo upload
Peobody wrote: Thu Aug 11, 2022 6:37 pm I know I am two years late but as a imgbb user I thought I would post that when inserting an image hosted on imgbb you need to use their Direct Link embed code url.
And I'm against external hosting as if something breaks with the links then the images are gone forever just like when photobucket decided to start charging a lot of people stopped using the service and a lot of images where broken
At least with uploading them up to the server they will always stay here :D
I would never stop it mind I would just discourage it
Re: Photo upload
Adding an image in a signature requires external hosting. A loss there is not catastrophic though. Uploading the image as an avatar instead of putting it in the signature may be the better way to go.
Re: Photo upload
Peobody wrote: Fri Aug 12, 2022 12:46 pm Adding an image in a signature requires external hosting. A loss there is not catastrophic though. Uploading the image as an avatar instead of putting it in the signature may be the better way to go.
Yes I was talking about just general images like you you are showing someone something has helpful then that help then goes!
It's not the end of the world its just my preferred option then no risk of losing it that's all
