Zumo 590 for sale
Been liked: 265 times
Zumo 590 for sale
Garmin 590LM for sale
Comes with two batteries, case, ram mount arm and back mounting plate and car mount and charger
You will need a ram ball to mount it on to your bike
Maps are fully up to date and has lifetime updates for the maps
The bike mount wiring has been modified they normally come with around 7 foot of cable with a USB, mic, audio out and AUX or something like that!
I have removed all these from the mount and attached a plug with just power on it as I had no need for the rest of the wiring as I use a bluetooth headset and didn't want 7 foot of wiring under the tank! plus I could easily remove the mount if I wanted.
I am looking for £250 posted ono
