595 display
CVO Paul
595 display
Post by CVO Paul »
Hi Anyone not like the display. I know they say the new screen reflective properties are better then the old. I find the screen to be almost like an LCD screen where it is dark at certain angles. I have moved it up and down and no real changes. I have brightness all the way up and the screen setting on day. Any of you having these issues. Thanks
Moose
Been liked: 21 times
Re: 595 display
Post by Moose »
might want to change the colors of your routes
Breezly
Has liked: 22 times
Been liked: 32 times
Re: 595 display
Post by Breezly »
You can select a different map theme and if that does not help you can modify any of the map themes to have more contrast.
Moose
Re: 595 display
Post by Moose »
pm me and I'll send you a different map theme that I use won't let me attach here
all you do when you get it is rename your ktmf file something original.ffff and then install the one I'll send then go to your map theme and pick that
Has liked: 414 times
Been liked: 229 times
Re: 595 display
Moose wrote: Wed Aug 15, 2018 9:36 am pm me and I'll send you a different map theme that I use won't let me attach here
What is the file extension and I will look at fixing it
JD Hog
Has liked: 17 times
Been liked: 8 times
Re: 595 display
Post by JD Hog »
I sent you a PM about this.
Jim Diebolt
Zumo XT
2015 Kawasaki 1700 Voyager
Northern California, USA
Moose
Re: 595 display
Post by Moose »
did not get pm send yours to gmills85@comcast.net
dave726
Has liked: 5 times
Been liked: 8 times
Re: 595 display
Post by dave726 »
Why not zip the file and post it?
Moose
Re: 595 display
Post by Moose »
maybe that will do it
un zip it that add it to your map themes and then choose it for your map theme
thanks dave
Moose.zip
(1.28 KiB) Downloaded 978 times
patrickg450
Re: 595 display
Post by patrickg450 »
when you put the file on the unit what is the secret? I had issues with "tweeking" and exsisting file, now I put "moose" on there and andI cant find it? Does "boogies theme" mean anything to anyone?
