595 display
595 display
Hi Anyone not like the display. I know they say the new screen reflective properties are better then the old. I find the screen to be almost like an LCD screen where it is dark at certain angles. I have moved it up and down and no real changes. I have brightness all the way up and the screen setting on day. Any of you having these issues. Thanks
Re: 595 display
You can select a different map theme and if that does not help you can modify any of the map themes to have more contrast.
- Moose
- Has liked: 3 times
- Been liked: 21 times
Re: 595 display
pm me and I'll send you a different map theme that I use won't let me attach here
all you do when you get it is rename your ktmf file something original.ffff and then install the one I'll send then go to your map theme and pick that
- Site Admin
- Has liked: 424 times
- Been liked: 241 times
Re: 595 display
I sent you a PM about this.
Jim Diebolt
Zumo XT
2015 Kawasaki 1700 Voyager
Northern California, USA
Zumo XT
- Moose
Re: 595 display
maybe that will do it
un zip it that add it to your map themes and then choose it for your map theme
thanks dave
thanks dave
- Moose.zip
- (1.28 KiB) Downloaded 1137 times
Re: 595 display
when you put the file on the unit what is the secret? I had issues with "tweeking" and exsisting file, now I put "moose" on there and andI cant find it? Does "boogies theme" mean anything to anyone?
