Zumo 595LM Not Recognized MacBook Pro M1 Max?
PaulaRay
Has liked: 85 times
Been liked: 11 times
Re: Zumo 595LM Not Recognized MacBook Pro M1 Max?
Post by PaulaRay »
Your welcome jfheath...... Thanks again! ;)
PaulaRay
Has liked: 85 times
Post by PaulaRay »
Bluenoser2 wrote: ↑Sun May 01, 2022 8:47 pm
PaulaRay wrote: ↑Sun May 01, 2022 5:16 pm SOLVED!! First, a huge THANK YOU to everyone here for all your time in helping me get this resolved!
My son-in-law gave me the following Dynex USB 2.0 hub along with the power adapter. This along with a USB-C to Mini-B Belkin cord and the oem Garmin cord did the trick. I did tests with the power adapter with and without it which worked either way. I'll probably just use the power from the MacBook Pro M1 making it one less cord to plug in.
This particular hub has been discontinued but, there are a few of these on eBay (link below) with one being new. I would say any 2.0 hub will do the trick just as long as it has 480Mbps for data.
I'm extremely happy with this getting me up and going but, I still feel the same about Garmin. They really need to get their act together and catch up with today's technology when it comes to Mac's. Even the newer units for example; Zumo XT and GarminDrive units as listed here are giving people fits;
https://support.garmin.com/en-US/?faq=K ... KQK5vAeKD8
And Here
https://support.garmin.com/en-US/?faq=n ... s1M7aSrGF7
Although not on that list, my 595LM is and has been checked on MTP Auto Detect sine day one. I did try the others with all three not being recognized during tests "without" this old 2.0 USB hub.
Anyway, I whined enough about Garmin.......
Once again, Thank You to everyone here for your help!! I sincerely appreciate it more than you'll ever know. I'm sure this thread will help others that found themselves in the same jam as I was. πŸ‘πŸ˜Š
Dynex 4 Port USB 2.0 Hub DX-4P2H
https://www.ebay.com/sch/i.html?_from=R ... _&device=c
Belkin F2CU034bt06-BLK 2.0 USB-C to Mini-B Cable
https://www.belkin.com/au/cables/cha...c/p/p-f2cu034/
Ray: That's awesome! Thanks so much for posting this! So glad you kept working at it. I'm sure your post will help many others with the mysterious Mac connection issues. It's still puzzling why some don't have any problems. Take care and best regards, David
Thank you David! It is indeed, very puzzling. You take care as well, best regards! ;)
midlife
Post by midlife »
PaulaRay
I have just ordered the USB hub and will give this a go. Thank you for finding a solution as garmin and apple certainly don't care.
best wishes Graham
will try not to piss too many people off
PaulaRay
Has liked: 85 times
Post by PaulaRay »
midlife wrote: ↑Tue May 03, 2022 7:04 am PaulaRay
best wishes Graham
You're very welcome Graham!! I'm super glad that you came across this thread. This forum along with all of it's members are in a word, Awesome. You'll find more here than Garmin could ever wish for. Best wishes as well! Ray πŸ‘πŸ˜Š
midlife
Post by midlife »
PaulaRay wrote: ↑Tue May 03, 2022 12:54 pm
best wishes Graham
You absolute star I have just had my data hub delivered and for the first time it recognises the BMW nav 6. Now to sell a recon windows laptop :D
If you don't mind I would like to put the solution up on the garmin and apple forums.
american cousins rule
Graham
PaulaRay
Has liked: 85 times
Post by PaulaRay »
πŸ€— πŸ‘
PaulaRay
Has liked: 85 times
Post by PaulaRay »
midlife wrote: ↑Wed May 04, 2022 9:05 am
best wishes Graham
Graham
Thanks again Graham! Absolutely, go ahead and place this solution in other forums. I did create a thread in the Apple forum here https://discussions.apple.com/thread/25 ... login=true back on March 20th but, for some reason I couldn't post the pic's like I did here.
Here's another one as well;
https://www.horizonsunlimited.com/hubb/ ... k-102788-2
jmsoulard
France
Post by jmsoulard »
Hi,
The issue is that the Macbook Pro M1 doesn't recognize the Zumo. You just have to use the cable that goes with the sumo and a USB2.0 speed adptator to fit with the macbook. For example:https://amzn.eu/d/a207GUd. With that cable and this adaptator the macbook recognizes the Zumo (you may have to wait a few minutes and check it in the finder). Once the Sumo is recognized in the finder it is also recognized in Garmin Express.
