Update times
kernowing
Has liked: 130 times
Been liked: 58 times
Re: Update times
Post by kernowing »
I had wondered about that Russ. I'll do seperate updates next time (if I remember :oops: )
2007 GL1800 Goldwing
Zumo 660LM
alan sh
Has liked: 6 times
Been liked: 26 times
Re: Update times
Post by alan sh »
If you run a speed test and it looks OK, it could be the routing from your ISP onwards. You could try changing your DNS settings to 1.1.1.1 and see if that makes a difference.
I’m in the UK on a 200mb/sec line and I get a 200mb/sec download from Garmin, so I know it should be faster than you are getting.
Alaj
Alan
kernowing
Re: Update times
Post by kernowing »
Thanks for the suggestion Alan. I've set the DNS to 1.1.1.1
I have a Nuvi awaiting an update, I'll give it a go tomorrow. Will this setting affect anything else on the laptop?
Zumo 660LM
Has liked: 410 times
Been liked: 229 times
Re: Update times
kernowing wrote: Wed Aug 29, 2018 11:08 am
Stu wrote: Wed Aug 29, 2018 11:01 am It calculates it depending on your Internet speed
Broadband speed is 51.9 Mbps which I thought was quite reasonable.
Express says it's copying files at 217 kb/s and now has 5hrs 3mins to go!
Not too worried--just like to know about these things. :)
I'm only on a 30 meg download and showing 1 hour 20 mins :lol: at a rate of 4.1 MB/s
I wonder if there was a problem with your ISP as that seems a long time at that given speed! or maybe a problem with your WiFi?
kernowing
Re: Update times
Post by kernowing »
It's always been pretty much the same--extremely slow update times. I did connect via an ethernet cable after Alan's suggestion. Also, following Alan's suggestion, I reset the DNS.
I've just plugged in the Nuvi for the update and it's absolutely flyin'!!! :o
6MB/s and less than 40 mins to completion (according to Express)
Edit--the rate has now dropped to 3.4MB/s but still more than 10times faster than before. Big thanks to Alan SH :)
Zumo 660LM
Re: Update times
next time there is an update try it on a night again to see if its slow
the speed may have been throttled at busy times although if your package sates you should get a minimum of say 50 meg then you should have decent speeds at all times
Has liked: 101 times
Been liked: 220 times
Re: Update times
Stu wrote: Thu Aug 30, 2018 9:21 am next time there is an update try it on a night again to see if its slow
This is a very good point that I'd forgotten about. I generally do all of my updating beginning at midnight-ish. Lunch and evening time traffic makes my internet connection scream to a crawl.
joebedford
Re: Update times
Post by joebedford »
Are you suggesting that the map downloads TWICE for simultaneous PC and device update?
Has liked: 337 times
Been liked: 366 times
Re: Update times
No. Most of the files are shared but there are some files unique to each and both use different map formats.
alan sh
Has liked: 6 times
Re: Update times
Post by alan sh »
No, it doesn't
Alan
