Newbie
robfin
Newbie
Post by robfin »
Hi, Thanks for the add!
Just upgrading from a Zumö 550 to XT.
Does anyone know of a converter from the 550 power plug, wth the two screws to the XT power plug?
To avoid having to retire the unit for power from the bike ignition.
Thanks.
Has liked: 140 times
Been liked: 436 times
Re: Newbie
Welcome to the forum.
Sorry that I can't help you with your wiring/adapter question.
Has liked: 416 times
Been liked: 907 times
Re: Newbie
You need to use the power cable supplied with the XT. it smooths the power steps it down to the right voltage, behaves like a fuse and guards against polarity reversal.
Apart from that the connectors to the mount are not the same style.
ZFtracker
Has liked: 16 times
Been liked: 30 times
Re: Newbie
Post by ZFtracker »
Welcome, Robfin.
Zumo 590
Montana 610
Drive 60
inReach Mini
