Newbie
robfin
Newbie
Post by robfin »
Hi, Thanks for the add!
Just upgrading from a Zumö 550 to XT.
Does anyone know of a converter from the 550 power plug, wth the two screws to the XT power plug?
To avoid having to retire the unit for power from the bike ignition.
Thanks.
Re: Newbie
Welcome to the forum.
Sorry that I can't help you with your wiring/adapter question.
Re: Newbie
You need to use the power cable supplied with the XT. it smooths the power steps it down to the right voltage, behaves like a fuse and guards against polarity reversal.
Apart from that the connectors to the mount are not the same style.
ZFtracker
Has liked: 22 times
Been liked: 39 times
Re: Newbie
Post by ZFtracker »
Welcome, Robfin.
Zumo 590
Montana 610
Drive 60
inReach Mini
