When I power up my Garmin Zumo XT, I get the message, "Maps are corrupt and cannot be used. Go to www.garmin.vom/express to download the latest maps. OK"
How do I get rid of that message. The Garmin Zumo XT does seems to work just fine, despite that message.
Maps Are Corrupt And Cannot Be Used
- Has liked: 71 times
- Been liked: 191 times
Re: Maps Are Corrupt And Cannot Be Used
Remember that there should be only one active routable map for an area.
Un-check the non-Garmin maps in myMaps.
If the message persists, remove all the 3rd party maps and replace one at a time.
You could also try running JaVaWa's Device Manager and see if that throws up any errors
https://www.javawa.nl/jdm_en.html
Javawa's Device manager does not work for the XT. The XT uses MTP and that is not supported by Javawa Device Manager!sussamb wrote: ↑Sun Dec 17, 2023 7:59 am You could also try running JaVaWa's Device Manager and see if that throws up any errors
As is often the case, when I am looking for other things online, I run across something that I was looking for in the past. I think the reason I was getting the message: Maps Are Corrupt And Cannot Be Used is because I added a map in UTF-8. In retrospect, I should have used maps in Latin-1 format.
