NT or NTU?
Fitz
Been liked: 3 times
Ireland
NT or NTU?
Post by Fitz »
Possibly a dim question but what's the difference between an "NT" map and an "NTU" map?
Thanks!
Has liked: 371 times
Been liked: 380 times
Re: NT or NTU?
NTU includes certain characters/alphabets not in the NT map, U stands for Unicode.
Unicode version can display cyrillic and some other languages characters and signs (like greek, polish,latvian etc)
Fitz
Been liked: 3 times
Ireland
Re: NT or NTU?
Post by Fitz »
Thanks! :)
tonkatoy001
Re: NT or NTU?
Post by tonkatoy001 »
Not sure if this is correct or not but my Zumo550 seems to use the NT maps and the 395 uses the NTU maps. I have both sets of maps installed on Basecamp.
I can create a route on the NTU maps on Basecamp and use it on the 550 but it always recalculates because the same maps are not installed. Not caused me a problem so far tho'
Tonka
Re: NT or NTU?
Correct, earlier ones use NT maps, later ones NTU.
danielb
Singapore
Re: NT or NTU?
Post by danielb »
Can the XT read unlocked/free NT maps?
Re: NT or NTU?
I've partly answered this elsewhere, but to amplify there are no 'free' NT maps unless you are talking about pirated ones, which we won't discuss on this site. CN maps from other devices are locked to the device, unless they were supplied on a card from Garmin in which case the card can be used in any device.
danielb
Singapore
Re: NT or NTU?
Post by danielb »
No. Not pirated maps.
Sources of maps are from here:
NT Maps
https://buy.garmin.com/en-US/US/p/89538
Free Maps
http://nightrider.info
Re: NT or NTU?
Then the Garmin card will work but not sure about the other maps as not used them but they should be fine looking at the description.
