man_mark_7
Post by man_mark_7 »
Same here, odd the Android app version of Tread only went from 2.08.28 to 2.08.29.
I did notice that if I change a track color on the Tread app, it syncs to the XT2, but the track always opens showing track color as "acceleration" instead of "none". Also on some tracks if I flip to "none" it still shows the same multicolor view I see in all the other "speed", "acceleration", "sharp turns". views and they all look identical. :roll:
2 steps forward, 1 back.
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Post by turbo19 »
New Software versión for the XT2 4.70
has anyone tried it? Thanks,
turbo19
Andorra
Post by turbo19 »
New Tread version for Android 2.08.30 (2024-05-06).
turbo19
Andorra
Post by turbo19 »
I´ve done some tests of the new version 2.08.30:
- I cannot design routes with off-road tracks with the Tread App, in any of the modes (Adventure, shortest route, etc.). In all of them, recalculate a straight line and not draw the route on offroad tracks.
- When I design the same offroad routes on the XT2 device, then it does draw the routes in the route planner, and I get it to draw the offroad tracks.
- I have been checking all the route settings and there are no prohibitions in either of the 2 planners. Previously, the Tread app allowed offroad routes to be drawn perfectly when a WP was placed in the middle of an offroad track.
- It seems that if I check the "avoid unpaved trails" option the Tread App route planner works better :lol: :shock:
do you have this same problem? Thanks ;)
turbo19
Andorra
Post by turbo19 »
New Tread version for Android 2.08.35 (2024-07-08)
from Garmin website:
https://support.garmin.com/en-CA/?partN ... b=software
Version: 2.08.35
Release Date: 7/08/2024
Fixed various issues
turbo19
Andorra
Post by turbo19 »
New Tread version for Android 2.08.36 (2024-07-24)
Tread app updates.jpg (132.38 KiB) Viewed 5512 times
Sean OZ
Has liked: 25 times
Been liked: 20 times
Australia
Post by Sean OZ »
Garmin made out that the new Tread APP was going to be the "Bees Knees" for the new Zumo XT2. Seems that so far, it's as about as useful as a dead Blow Flie floating in a dunny bowl!
Zumo XT2
2020 Honda CB500X
15 Aug 2024 Garmin Tread App update
Update available for both android and ipad in last 7 days.
Screenshot 2024-08-15 at 10.48.53.jpeg.png (434.59 KiB) Viewed 5347 times
Re: 15 Aug 2024 Garmin Tread App update
I love it when companies provide detailed release notes so I know what bugs have been fixed and I can fully appreciate all the new "functionality".
:lol:
turbo19
Andorra
Post by turbo19 »
Thanks @jfheath . Please use the "Latest XT2/Tread" post for this, that way we can have all the posts together. Thanks for the info. ;)
Ok thanks for spotting this. I Missed this thread - now moved to here. jfheath (moderator)
