SD Card
burtsr
SD Card
Post by burtsr »
MY XT shows 28+ gig or memory. I put in a 64g SD card but the unit does not recognize it. I tried a 8g with the same results.
How do you get the gps to recognize the card?
thanks
raza
Has liked: 25 times
Been liked: 15 times
Slovenia
Re: SD Card
Post by raza »
SD mast be Fat32 formatted
Reason: Typo
Re: SD Card
SD cards are typically formatted as exFAT. Garmin devices only recognize FAT32 formatted card. If your card is exFAT formatted then it will need to be reformatted as FAT32. Note that Windows FAT32 formatting has a maximum size of 32 GB. You will need to use a third party formatting tool to format it to its full 64GB capability. I used AOMEI Partition Assistant (free version).
twowheelstom
Has liked: 146 times
Been liked: 54 times
Re: SD Card
Post by twowheelstom »
i have an XT with 64gb card installed, how do you check/verify on the XT that there's a card installed and that it's recognized?
Zumo 396
1994 Yamaha 250
burtsr
Re: SD Card
Post by burtsr »
I had a 16g card that I did a long format on and now it shows. Guess it didn't like the quick format.
Thanks for the help! Much appreciated.
Re: SD Card
twowheelstom wrote: Wed Feb 28, 2024 11:24 pm i have an XT with 64gb card installed, how do you check/verify on the XT that there's a card installed and that it's recognized?
That is a good question. I would like to know this as well. It is reassuring to see the card in a file explorer and via BaseCamp but to not be able to see anything about it on the XT itself is weird. I feel like I'm missing something.
Re: SD Card
:roll:
Why did you install the card?
Try to use the card for the purpose you installed it.
Add a few routes, a few mp3 files.
If the routes are available for import, if the music plays, it was recognized.
Learner
Re: SD Card
Post by Learner »
I have an XT2 and my device does not recognize the card. I have a 256GB card formatted as FAT32. I tried adding GPX and MP3 directories and nothing seems to get the card recognized. I know it's not recognized because if I try to download the Bird's Eye view maps, I cannot configure my XT2 to use the SD card for storage. There's nothing in the Users Manual other than it supports up to 256GB and it has to be formatted to FAT32. Is there something else that needs to reside on the SD card? Or, some kind of naming convention? (Tried to name the SD card Zumo XT2)
burtsr
Re: SD Card
Post by burtsr »
I installed the card just because. I don't need it for anything at the moment, but who knows what the future may bring. I have over 3,000 mp3 files I may load.
Burt
MotoToph
Has liked: 32 times
Been liked: 16 times
Re: SD Card
Post by MotoToph »
Here is an excellent FAT32 GUI. Follow the link and click on the picture.
http://ridgecrop.co.uk/index.htm?guiformat.htm
ZUMO XT
K1600GT
