Other satnavs
- Has liked: 63 times
- Been liked: 59 times
- Contact:
Other satnavs
Does anyone know if you can purchase Garmin maps and use Basecamp to export .gpx files without owning a Gamin satnav?
- Has liked: 15 times
- Been liked: 36 times
Re: Other satnavs
You can download Basecamp, but Garmin maps require a device and serial number to unlock.
Michael S.
Trinity, North Carolina
- Contact:
Re: Other satnavs
That's what I thought. I'm leading a seminar on satnavs for my local club in a couple of weeks, and just wanted to clarify how interchangeable the various devices and routing software are. The upshot is that using Garmin software to route TomTom devices is possible but expensive.
- Has liked: 71 times
- Been liked: 191 times
Re: Other satnavs
Basecamp works just fine with free Open Street Maps (.gmap format), and TomTom does contribute to OSM. I'm uncertain about the practicality and limitations of using a .GPX file in a TomTom, or converting a .GPX to an .ITN file. ITNConverter used to work but it has been decades since I played with it.
