Other satnavs
None Zumo related? then feel free to chat about it here anything goes.
colirv
Has liked: 53 times
Been liked: 43 times
Other satnavs
Post by colirv »
Does anyone know if you can purchase Garmin maps and use Basecamp to export .gpx files without owning a Gamin satnav?
Colin
BMW R1250RS
https://www.namrider.com
MSTOCK27370
Has liked: 13 times
Been liked: 33 times
Re: Other satnavs
Post by MSTOCK27370 »
You can download Basecamp, but Garmin maps require a device and serial number to unlock.
Michael S.
Trinity, North Carolina
Has liked: 343 times
Been liked: 368 times
Re: Other satnavs
Well it's possible although I'm unclear why you would wish to, but it would mean buying a Garmin map on a sd card.
colirv
Has liked: 53 times
Re: Other satnavs
Post by colirv »
That's what I thought. I'm leading a seminar on satnavs for my local club in a couple of weeks, and just wanted to clarify how interchangeable the various devices and routing software are. The upshot is that using Garmin software to route TomTom devices is possible but expensive.
Colin
BMW R1250RS
Has liked: 60 times
Been liked: 145 times
Re: Other satnavs
Basecamp works just fine with free Open Street Maps (.gmap format), and TomTom does contribute to OSM. I'm uncertain about the practicality and limitations of using a .GPX file in a TomTom, or converting a .GPX to an .ITN file. ITNConverter used to work but it has been decades since I played with it.
