Planned distance not making sense
Re: Planned distance not making sense
If you can't install Basecamp, for whatever reason, you could try MRA: https://www.myrouteapp.com/en/
In addition to an App for IOS and Android, it is also webbased. Lots of people like it, so it must provide reasonable to good results. (Although I still prefer Basecamp)
Chopperbob
- Has liked: 21 times
- Been liked: 4 times
In the mean time I have found a way to modify the exported file via another system to Garmin GPX, which seems to also have resolved the problem!
via this website:
https://gpxshaping.de/GPX/GpxShaping.html
The distances now make sense, and importing into Explore using routes rather than tracks (too many waypoints), however it cuts of a lot of the curved roads....
Perhaps need Garmin Basecamp software to make it better for planning routes...
via this website:
Chopperbob
to be honest, the whole experience with the Zumo XT is sh!tty
Spend 500eur on a unit and there is no way you can do decent route planning because the sh!tty software either on the unit itself or provided by Garmin doesn't work.
Importing tracks from other systems is marginal at best.
This whole experience makes me feel like throwing the whole thing away, wouldn't even want to sell it..
A winning combination is Basecamp for route planning and these forums for working through the idiosyncrasies of the XT and Basecamp. Garmin is trying to steer us to mobile device route planning tools like Garmin Explore and Tread but only a few people here have indicated that they find them of value.
- Has liked: 148 times
- Been liked: 139 times
Don't give up yet!
I have owned a bunch of GPSes over many years and this phrase you posted is key to the problems you are having: "Importing tracks from other systems..." Trying to get consistency between different units, different software, and different maps can drive you crazy.
This is why I do all my route planning in Basecamp (with Google maps open in the background to visually verify choices). Yes, BC is a bit clunky and not the easiest app to learn. But once you are done making a route, it stands a much better chance of working properly on your XT than a route from any other source. I'm not saying other sources can't work. I am saying that they need to be carefully checked and edited and the best tool for that is BC. So why not bite the bullet and just start out in BC? That works for me, and has done so for many thousands of miles ridden in previously unfamiliar territory. But I understand it's not everyone's ideal solution.
Chopperbob
The problem with base camp is that it needs to connect to the Zumo XT to upload the maps. And it won't connect, therefore no planning possible!!
Any body can explain how I can get Explore to make a route between two or more waypoints?
Robert
Robert
No - that isn't correct. In Garmin Express, you can install the same maps that you have on your XT to the computer.Chopperbob wrote: Wed May 22, 2024 3:57 pm The problem with base camp is that it needs to connect to the Zumo XT to upload the maps. And it won't connect, therefore no planning possible!!
Ignore 'Manage Maps' on the right. Select Map Details instead.
Don't change the location from the one it suggests.
Some time later - 2 or3 hours on my computer - it will have installed, and Basecamp will find it.
I assume that if your Zumo won't connect you will have to export the routes, tracks and waypoints that you need from Basecamp to a GPX file and put it into your SD card slot - or create a gpx file and email it to your phone and let Garmin drive put it onto the Zumo.
The Explore App. Although you can place waypoints, they do not form part of the route like they do in BAsecamp, Kurviger, My Route App. THey are just shown on the screen.Chopperbob wrote: Wed May 22, 2024 3:57 pm Any body can explain how I can get Explore to make a route between two or more waypoints?
Robert
If you make a route consisting of straight lines in Explore, when it is transferred to the Zumo it will create a route that goes through the 'corners' in the route - but the route itself has no route via points and shaping points. That means if it gets recalculated or edited, you end up going straight to the end. But it doesn't get altered accidentally. If you deviate, it finds a way to get back onto the magenta line again. Its a good solution. It made sense the few times that I tried it. I had to negotiate a road closure in the Pennines, so I had to go way of route, but as soon as I started heading towards the magenta line ahead - it spotted it and navigated me towards it.
See my link and explanation here. app.php/ZXT-P61
That's new to me. All my navs, even the 12 y/o Nuvi 1450 can connect to BC.Chopperbob wrote: Wed May 22, 2024 3:57 pm The problem with base camp is that it needs to connect to the Zumo XT to upload the maps. And it won't connect,
Another alternative is to plan a route in Furkot.com. The full version to include the Via and Shaping points for newer navs is I think $14/yr (Probably as Kurviger), but much easier to learn than the BC and the GPX files are good for Garmin.
What kind of computer? If it's a Mac you will need Android File Transfer (free app) to connect an XT. If Windows, you'll need help from others in this forum.Chopperbob wrote: Wed May 22, 2024 3:57 pm The problem with base camp is that it needs to connect to the Zumo XT to upload the maps. And it won't connect, therefore no planning possible!!
Robert
Which USB cable? The one that came with it should work; some aftermarket ones stubbornly don't, but some do. Keep trying. Also try different USB ports on your computer.
That is my thinking too. Some cables will not carry data (charging only cables). A charging only cable is needed when you want to use the XT in a car, powered by plugging it into a USB port in the car. Such a cable will not work to connect the XT to a PC. I have also experienced devices that were not recognized when plugged into a certain USB port on my PC but would work with the others.danham wrote: Thu May 23, 2024 12:52 pm Which USB cable? The one that came with it should work; some aftermarket ones stubbornly don't, but some do. Keep trying. Also try different USB ports on your computer.
