Was GE 7.21.0 but updated to 7.22.0.0
I have used Garmin Express over the past 12 months for map updates on a ZUMO XT2 and noticed my M1 iMac storage filling up. The usual warnings about keeping backups/renaming files before any deletions.
This information may help:
Maps on iMac
user/library/application support/Garmin/maps/XXXX.gmap
Map downloads
~/Library/Application Support/Garmin/Express/UniversalMaps
XT2 with Android File Transfer for maps
.System/Map
Removed the map "Downloads" in the UniversalMaps folder to recover 22GB but moved copies to an external drive.
Dave
Garmin Express - retained downloads
- Has liked: 71 times
- Been liked: 191 times
Re: Garmin Express - retained downloads
Equivalent (hidden) folder for Windows PC is C:\ProgramData\Garmin\CoreService\Downloads
I delete this folder after every update of anything from Garmin. It seems to contain only duplicates of everything installed, but there is no way to actually use the files after installation completes. I don't bother to backup the files, Express will download them again if needed.
- Has liked: 146 times
- Been liked: 452 times
My C:\ProgramData\Garmin\CoreService\Downloads directory is empty. What isn't empty is C:\ProgramData\Garmin\Maps\RMU\NA\. It contains the installation files (.gmap, .cab, & .msi) for the current and previously installed maps (38.8GB worth). I suspect these are created by the install to PC function of Express. The existence of .msi files makes me think that they could be reinstalled but whether doing so would result in an unlocked map is a question.
