Fresh Zumo XT: problem whit country at startup
mavvy
Italy
Post by mavvy »
Hello everyone,
i have a strange problem with a brand new Zumo XT. When I turn off completely the Zumo, when i turn on again the device every time asks to select the country. No problem if simply go in standby. All the personalization are saved too without problem. I see another Zumo xt with the same firmware that i've installed (6.60) and not figure this problem. Did you see this problem before and how can be solved?
Tnx!
Has liked: 369 times
Been liked: 780 times
Re: Fresh Zumo XT: problem whit country at startup
Welcome to the forum @mavvy
The problem may be that you have yet to put it on the bike or in the car and take it for a ride.
It knows where you say that you are, but it doesn't know for itself where you are until it has got some reliable data from the satellites - and for that you need to be driving around. Walking around doesn't fool it.
mavvy
Italy
Post by mavvy »
jfheath wrote: Tue Jun 04, 2024 7:22 pm Welcome to the forum @mavvy
Hi @jfheath and thank you for the welcome. Your solution worked fine! It's incredible that i have installed and configured two of this device for friends effetively every time on openspace and worked fine. Arrived my turn and i configured inside house and don't know about this "feature" :lol:
Tnx again for your support!
Glad that it worked.
That feature surprised me too. I got mine during Covid and use of cars was limited to a single trip to the shop every two weeks. But we were allowed to exercise every day. Walks. So it came walking with us. 3-6 miles every day. I plotted the route - but it wasn't playing - all sorts of weird behaviour. Clearly it was ignoring small changes in location within a given time frame. You might remember the hundreds of tracks plotted around your house, and the icon that wobbled around onthe screen ? The XT doesn't do that. After only small movements in the same area - it stops updating until it gets a bigger movement. Clearly 3mph on footpaths isn't good enough to trigger the Satnav to wake up to the fact that it isn't still in the shop.
