New type of "Routing Point"
Just back from an 1100 mile trip round SW Ireland, my first using the XT in anger. Taking on board a lot of what I've picked up on here I must say the XT performed faultlessly (apart from one instructing me to go "off road" which was actually a slip road onto a motorway!). One thing I'd like opinions on, I cut down on the number of routing points (to strictly necessary ones I was definitely going to pass through) but find there were times when I'd have liked notifications of upcoming points of interest, but also to have the ability to miss them without being forced to go back through them if need be. (eg points of interest near the main route) The Montana 700i was excellent at this. Does anyone else see the need for "Alerting Shaping Points" for want of a better description?
- Has liked: 146 times
- Been liked: 452 times
Re: New type of "Routing Point"
Yes, routinely. My trick is to strategically place a Via point on the road somewhere before the potential stop, giving it a name like "Next right for Gopher State Park", or "Go straight for coffee at Bobs Diner". If you choose not to stop, riding through that point on the road satisfies the XT that the point was visited allowing you to ride on.
- Has liked: 4 times
I agree, "Alerting Shaping Points" would be a valuable feature to have. It would provide notifications for points of interest while allowing flexibility to skip them if needed, enhancing the overall navigation experience.
That works fine except where the point you may want to visit involves a bit of navigation to get there! That's where I see this "Alerting Shaping Point" being really useful.Yes, routinely. My trick is to strategically place a Via point on the road somewhere before the potential stop ....
Reason: quote format Typos
I don't understand how it would help in this case so am curious about what you envision. The way it can work now is that you set your alerting shaping point and then set the potential POI as a shaping point. If you chose to not to divert, the POI shaping points will be ignored once the XT2 realizes that you are have passed it. The only challenge is when the re-entry point upon return from the POI is not in the same place as when you diverted. In that case, not diverting to the POI would require manual navigation to rejoin the route somewhere past that POI. Now, a point that would prompt for the loading of a different route, well that would be something! Imaging not having to stop the current route and load the alternate route but instead be prompted for continuing on or loading a specified alternate route.QuantumQuartz wrote: ↑Thu Jun 27, 2024 2:04 am I agree, "Alerting Shaping Points" would be a valuable feature to have. It would provide notifications for points of interest while allowing flexibility to skip them if needed, enhancing the overall navigation experience.
I understand your point. An alerting feature for shaping points could greatly improve the navigation experience. It seems advantageous for the automatic handling of points of interest along a path, eliminating manual input, particularly when choosing to stick with the current route or opt for another. Such a feature would likely boost both efficiency and convenience, facilitating seamless navigation, even when re-entry points vary.
