Deleting old maps.
wks
Has liked: 23 times
Deleting old maps.
Post by wks »
Hi all, as title says is it OK to delete old maps. Have found the thread about deleting the express folders but was not sure about the maps.
TIA and a merry christmas to all.
Has liked: 347 times
Been liked: 370 times
Re: Deleting old maps.
If you mean on your computer then yes unless you need some for BaseCamp
wks
Has liked: 23 times
Post by wks »
Thanks for reply. It is the maps on the computer. I only need the latest? or do I need them for other things.
Has liked: 62 times
Been liked: 158 times
I've never found a use for old maps and they do take up a substantial amount of storage. You can delete them from a PC just as you would uninstall an app. Go to Settings→Apps→Installed Apps→Garmin City Navigator 20xx.xx , click the three dots and Uninstall. You can also just delete them from File Explorer, but that may leave garbage in your Apps list.
wks
Has liked: 23 times
Post by wks »
Many thanks.
wks wrote: Wed Dec 18, 2024 11:42 am Thanks for reply. It is the maps on the computer. I only need the latest? or do I need them for other things.
You don't even need the latest if you don't use BaseCamp
wks
Has liked: 23 times
Post by wks »
sussamb wrote: Wed Dec 18, 2024 4:18 pm
Thanks I use basecamp all the time. I'm not very good at it but it does everything I need. I don't post a lot but do a lot of reading and thanks to everybody for making my life easier. :mrgreen:
Then you need the latest at least.
wks
Has liked: 23 times
Post by wks »
Hi another question. I have deleted all old map except the latest which are NT_2023_10.gmap and NTU_2025_20.gmap. When you go to ProgramData>Garmin>Maps there are 3 folders :-
City_Navigator_Europe_NT_2023_10.gmap
City_Navigator_Europe_NTU_2025_20.gmap
RMU
The RMU folder contains 1 folder called EU which contains 3 folders :-
2024_10
2024_20
2025_10
These appear to be maps can these be deleted?
TIA
All you need there is the folder with your latest map, the rest can be deleted as can any data in the CoreService folder.
