Hi .
I have managed to format my 660 internal drive.
I have managed to get it booting again but without the maps.
Garmin express will not recognise the Zumo so i cannot update the maps.
as an experiment I copied the system files from a Nuvi 550 to the zumo. garmin express then recognised it as a nuvi 550.
There was an old thread on here to fix this problem but now the links do not work.
Any one know where I can get the system files I need?
Cheers.
Paul.
Zumo 660 system files wanted.
Re: Zumo 660 system files wanted.
Thank you.
I am not sure which files I need.
I will look in to it further.
Cheers.
Paul.
Cheers.
Paul.
