turbo19
Has liked: 100 times
Been liked: 24 times
Andorra
Post by turbo19 »
I just did the tests, and in my case the phone calls continue to be interrupted when everything is installed with version 5.40. Therefore I will continue with the Explore cloud option without activating, and passing the tracks with cable like 20 years ago, thanks Garmin.
Has liked: 427 times
Been liked: 934 times
They have videos, logs from the XT2, logs from the phone everything that they need now for my phone call issue (which is different from @turbo19's - but I suspect not unrelated). After being fobbed off by the someone is working on it story, I take everything with a cellar full of salt. They didn't even bother to fix it on the XT2.
But - Am I fed up about it ? No, not really. I like the screen and the collections are something that can be used without Tread being involved, and it still works just like I used my XT1 - with Explore disabled on the XT1; with Tread installed but not allowed to synch on the XT2.
My phone call issue doesn't go away in that case - but it does if Tread is not installed at all. But not many people call me - ever. Partly because I'm not someone who feels the need to keep his phone with him at all times. That's what the landline is for. My mobile is for my convenience. Pity I've just got rid of the landline then.
I'm excited about the remote control for the handlebar. I've just got to get the fairing off to install it, and sit in the freezing cold working out how to program it. I'm waiting until my expectations of what it will do have subsided a little.
(My phone issue is that once a call has been recieved, the XT doesn't get the signal that it has ended. It thinks the call is still ongoing so the navigation instructions don't come back. If I wait for 3 minutes it disables bluetooth altogether and then eventually reconnects - but turns the music player on when it does so - even if it wasn't playing before!)
But I can get the XT2 to do what I want. It just irritates me when something that I find surprisng to have been in the design from the outset has been passed off as working and they seem to 'pretend' to be doing something about it. I've lost count of the number of issues I have raised over the years. No one of them has been fixed yet. So I will retract that statement as soon as I have a fault that has been addressed.
TheoTiger
Has liked: 5 times
Post by TheoTiger »
A new software update 5.4 for the Garmin XT2. Does anyone know what this update includes?
Dutchgixxer
Been liked: 9 times
Post by Dutchgixxer »
support for the garmin radar and some minor bug fixes
Has liked: 130 times
Been liked: 102 times
Dutchgixxer wrote: Thu Jan 09, 2025 7:18 am support for the garmin radar and some minor bug fixes
And probably new improved bugs have been introduced :roll:
turbo19
Andorra
Post by turbo19 »
I have done some tests, with Tread App and the XT2.
The good news is that it now appears that when the gpx are inserted into the internal memory or microSD, it appears that ALL of the gpx content is added to the XT2 and also to the Tread App. No tracks are lost along the way. Somethings seem to have changed in this regard.
Little by little Garmin, lest you fix everything at once :lol: .
Dutchgixxer
Been liked: 9 times
The latest treat version is 4 december 2024. So nothing has changed recently. This version works fine for me. Make a route and trackset in 1 gpx and i whatssapp this gpx to my self. Then open it in treat. It syncs perfectly
turbo19
Andorra
Post by turbo19 »
Zumo XT2 version 5.40 was released in January, and I'm sure the handling of GPX files when importing via the internal GPX folder is different. I used to have problems with some GPX files I had saved on my PC, but now I don't.
There were elements that were sometimes lost in the process of importing the GPX files.
turbo19 wrote: Fri Jan 17, 2025 7:42 pm Zumo XT2 version 5.40 was released in January, and I'm sure the handling of GPX files when importing via the internal GPX folder is different. I used to have problems with some GPX files I had saved on my PC, but now I don't.
I've not had the mental capacity in recent weeks to look at v5.40. I remember installing it, but then nothing much else.
But ... some elements were lost ... ?
If gpx files are sent to internal storage, then the XT2 will strip out the tracks and the saved waypoints / favourites from the gpx file and store them separately. This means that they are not available should you wish to import them again. But I haven't checked this for the recent update. I doubt they will have stopped that heppening - it was deliberately coded to do that. It doesn't do it if the gpx file is put onto SD card.
Odd things happen to routes from gpx files (points moved, routes changed) after synchronisation if you have Tread installed. They don't happen if Tread isn't installed on your phone; if data isn't allowed to be saved / synched; if the BT link is not intact.
But I go back to my first statement. I haven't checked out v5.40 - and I reckon it will be a few days yet before I can think straight for any length of time.
turbo19
Andorra
Post by turbo19 »
I was NOT referring to that. I already know that.
In previous versions of the XT2, when importing gpx files via MicroSD or Internal Memory, in some cases it caused a track within that gpx to be lost. For example, if the gpx had 16 tracks, only 15 appeared on the XT2. Now it seems that the import respects everything inside. I will continue doing tests.
According to what Garmin has told me this week, when we import Tracks originating from Basecamp (I'm talking about Tracks, not routes), it is NORMAL FOR THEY TO PRODUCE INTERRUPTIONS IN THE BLUETOOTH. Oh really?
What are Garmin engineers thinking? How will I know if some tracks that are sent to me via WhatsApp originate from Basecamp or not? What kind of engineers are there at Garmin? :shock: :lol:
Therefore I am testing importing gpx with and without origin in Basecamp, to see if the bluetooth interruptions are reproduced or not. Very unfortunate Garmin.
P.S. I'm going to copy this to the specific post of the bug. Thank you
