"Files Too Large" for update
gbyoung2
Re: "Files Too Large" for update
Post by gbyoung2 »
Wow!, that's crazy. My original 550 is only using a 4 GB card.
Guess I go through the process - again. :roll:
'95 Kaw Concours (207K), '02 Kaw KLR (60K), '67 Honda CL77 305 Scrambler (15K), '22 900 Ace Ryker Sport (5K and counting)
gbyoung2
Post by gbyoung2 »
That's it. I'm done fooling with this thing for a while. I've tried a number of SD cards from 8 gigs up to 32 gigs and get the same error: unable to complete route - out of memory. Gotta be something else going on.
MSTOCK27370
Has liked: 15 times
Been liked: 36 times
Post by MSTOCK27370 »
gbyoung2 wrote: Fri Mar 21, 2025 9:00 pm When calculating a route, if it has to go any distance, it goes to a certain %, usually just above 25, then hangs up. a note eventually pops up say that there's not enough memory to complete the route.
The SD card I'm using is an 8 GB, but this sounds more like an internal memory problem. Or is it?
When you connect the Zumo 550 to your computer are you able to use File Explorer to look at the SD card as well as the GPS internal drive?
How much free memory do you have on the Zumo internal drive?
Michael S.
Trinity, North Carolina
Has liked: 381 times
Been liked: 384 times
gbyoung2 wrote: Fri Mar 21, 2025 9:00 pm The SD card I'm using is an 8 GB, but this sounds more like an internal memory problem. Or is it?
Yes it is, nothing you can do about it except split routes that won't calculate into 2 separate routes.
twowheelstom
Has liked: 114 times
Been liked: 40 times
Post by twowheelstom »
another option instead of a long route is to make waypoints then on the 550 just select that waypoint as a destination and allow the 550 to calculate the route, doing it that way will allow you to change your route and the 550 will automatically recalculate, just having waypoints might not take up much of the 550 internal memory space
gbyoung2
Post by gbyoung2 »
MSTOCK27370 wrote: Sat Mar 22, 2025 1:36 am
The below is what I’m seeing and is what I think you’re asking:
Without the SD card installed, when I connect the 550 to my computer, it shows up as drive D:
If I install the SD card, it shows up as drive F:; The D: drive is showing.
If I look at the properties of drive D:, it says used space is 1.01 GB, with a free space of 119 MB.
If I look at the properties of F: drive, it says used space as 3.68 GB, with a free space of 26 GB.
FWIW – if I run a previous route with the SD card removed, it’ll go to about the same % place as before when it craps out for lack of memory.
I have screen shots of drive D: and drive F: contents if you need to see those.
twowheelstom
gbyoung2 wrote: Sun Mar 23, 2025 4:04 pm
the zumo might be using Internal Memory to do route calculations, maybe connect 550 computer and go thru Internal Memory and copy unused files to a new folder on computer, (just to be safe), files like foreign language files and vehicles you don't use, copy those to your computer then delete them on the 550 to make more room for Internal Memory route calculation space, deleting files from zumo Internal Memory can be risky, just be sure its files the 550 doesn't need for functioning operations.
Memory used for calculating routes etc isn't something a user can access. Only thing you can do is as I already posted, split the route into two.
