Hi Guys
Can anyone help .I have MRA gold but I cannot get a route to send to the Drive app
I've checked my setting and all seem ok. .
Any help would be appreciated
Cheers
MRA to Drive
- Has liked: 145 times
- Been liked: 452 times
Re: MRA to Drive
It has been awhile since I have done this but I recall that an iPhone behaves differently than an Android. The process described by @raesewell didn't work on my iPhone. Instead I had to 'share' the file with the Drive app.
- Has liked: 61 times
- Been liked: 59 times
- Contact:
Re: MRA to Drive
I tend to export the MRA gpx v1.1 to the machine I'm using (usually my tablet), then move it to my phone, either via email or simply by file transfer. Once it's on the phone, opening it or sharing it should give you the Drive option.
