MRA to Drive
Scarecrow
Been liked: 27 times
MRA to Drive
Post by Scarecrow »
Hi Guys
Can anyone help .I have MRA gold but I cannot get a route to send to the Drive app
I've checked my setting and all seem ok. .
Any help would be appreciated
Cheers
raesewell
Been liked: 17 times
Re: MRA to Drive
Post by raesewell »
Email the route to yourself and open it, select Drive when prompted.
Has liked: 145 times
Been liked: 451 times
Re: MRA to Drive
It has been awhile since I have done this but I recall that an iPhone behaves differently than an Android. The process described by @raesewell didn't work on my iPhone. Instead I had to 'share' the file with the Drive app.
colirv
Has liked: 61 times
Been liked: 59 times
Re: MRA to Drive
Post by colirv »
I tend to export the MRA gpx v1.1 to the machine I'm using (usually my tablet), then move it to my phone, either via email or simply by file transfer. Once it's on the phone, opening it or sharing it should give you the Drive option.
Colin
BMW R1250RS
https://www.namrider.com
Scarecrow
Re: MRA to Drive
Post by Scarecrow »
OK Guys
Thanks for the advice. all sorted
I was using Google Maps but had switched to the HERE TomTom by mistake :oops:
