Introducing TripManager
JS_racer
Has liked: 8 times
Re: Introducing TripManager
Post by JS_racer »
I was in the trips, on the xt.. selected some to rename, and got errors that said copy error or something.. don't exactly recall..
The high dpi on a 4k screen was super tiny.. lol..not sure if there was another way to see anything without a magnifying glass..
I'll look into the errors more .. I can't be the only one with them.. but possibly. I think garmin express tossed some of my old stuff on the new xt replacement..I'll document what I can... jist of it was selecting numbered trips, to rename..nothing fancy..
As far as the xt2... it will probably get sent back.. but I have till the 3rd of May to decide...
Has liked: 122 times
Been liked: 174 times
JS_racer wrote: Fri Apr 18, 2025 8:36 pm The high dpi on a 4k screen was super tiny.. lol..not sure if there was another way to see anything without a magnifying glass..
I (think to have) fixed the scaling on Hi-DPI. You can download V1.3.0.148 from my One Drive. https://1drv.ms/f/c/e97d3333e40b4915/Eq ... g?e=LONLWx
Can you confirm that works better?
JS_racer wrote: Fri Apr 18, 2025 8:36 pm As far as the xt2... it will probably get sent back.. but I have till the 3rd of May to decide...
TripManager should be able to do more than 62 Via points.
Frank
