Basecamp Update
Breezly
Has liked: 22 times
Been liked: 32 times
Re: Basecamp Update
Post by Breezly »
Yes, you need to use the 32 bit version of Google Earth or Google Earth Pro
Sleuth
Has liked: 14 times
Been liked: 16 times
Belgium
Re: Basecamp Update
Post by Sleuth »
Despite various solutions from the other knowledge base, I could never get the Link between Google Earth and BaseCamp to work.
While it would be nice, I would rather have BaseCamp up to date than keep trying to solve a situation caused by Google.
Perhaps the data mining tools of Google will change and BaseCamp can be linked again to Google Earth / Maps. Sorry I like Google search Engine, but the data mining of Google leaves much to be desired!
Maps: Europe NTU 2024.10
AlanI
Re: Basecamp Update
Post by AlanI »
Breezly wrote: Sat May 26, 2018 1:17 am Yes, you need to use the 32 bit version of Google Earth or Google Earth Pro
Well I've got the 64 bit version of Google Earth Pro along with BaseCamp 4.6.2 but still can't get 'View' to work. I wonder if reverting to the Google Earth of old is a cure and if so, where does one find it?
Has liked: 343 times
Been liked: 368 times
Re: Basecamp Update
Think you've missed the bit that says you need the 32 bit version of Google Earth :lol:
kernowing
Has liked: 131 times
Been liked: 58 times
Re: Basecamp Update
Post by kernowing »
sussamb wrote: Mon May 28, 2018 12:21 pm Think you've missed the bit that says you need the 32 bit version of Google Earth :lol:
As I have 64 bit version installed, would I be able to install the 32 bit version onto windows 10 and would I need to uninstall the 64 bit Version?
2007 GL1800 Goldwing
Zumo 660LM
AlanI
Re: Basecamp Update
Post by AlanI »
No, not really, but maybe I was reading too much into the word 'or' .
AlanI
Re: Basecamp Update
Post by AlanI »
kernowing wrote: Mon May 28, 2018 12:34 pm
Reading this https://productforums.google.com/forum/ ... D2M3MqBAAJ I think you possibly can.
Edit: Confirmation that this does work - hooray. I myself removed the GE 64 bit version from my PC and then followed the instructions (and link provided) in the referenced link above.
Imskier2
Has liked: 4 times
Re: Basecamp Update
Post by Imskier2 »
The new version is useless to me without Google Earth link. On my touring and HOG routes I verify and move every POI that I am going to on Google Earth. Really not good when leading a group of 25 bikes and you pass or miss a turn because you weren't able to view entrance on Google Earth. I will be using the older version unless they decide to bring back the link. Having the link outweighs any improvement that they make. Maps are still updated and it works fo me.
2022 Ultra Limited
Mean Green Machine
Radioactive Green/Vivid Black
Arizona
Re: Basecamp Update
There are no improvements with 4.7
It's simply been updated to remove certain features.
KiwiGPS
Has liked: 5 times
New Zealand
Re: Basecamp Update
Post by KiwiGPS »
Try the new Google Earth Pro version 7.3.2
Info here on the BaseCamp forum: https://forums.garmin.com/forum/mac-win ... source-fix
