CN NA 2021.10
- Has liked: 183 times
- Been liked: 166 times
Re: CN NA 2021.10
Garmin is getting bad as motorbike magazines when you see the June issue first for sale in April!
Re: CN NA 2021.10
Garmin Express still says my 660 should be running 2020.2
I have a nuvi 3790 which has had 2020.3 and now 2021.1 but my 660 is lagging well behind now.
Is this normal for Garmin to hold back zumo updates?
Re: CN NA 2021.10
I believe that Garmins "Lifetime" map updates only runs for an arbitrary length of time, not sure whether the 660 is now beyond that point but it could be the reason.Paul R wrote: Fri Jul 10, 2020 12:51 pm Garmin Express still says my 660 should be running 2020.2
Re: CN NA 2021.10
Yes, I think you are correct sussamb, NT maps are installed on my 660. I've never been this far behind on the version update though. How do you find out when a newer version is coming out?
