Combining routes
CollingsBob
Has liked: 144 times
Been liked: 21 times
Combining routes
Post by CollingsBob »
I edited a route this morning..and in the process ended up with the routes in 2 sections..when I highlight the first section of the route it doesn't highlight the whole route, only the first part. The same is true when I highlight the 2nd half of the route.
How do I combine the 2 halves of the route into one route?
Certified JB Welder
CollingsBob
Re: Combining routes
Certified JB Welder
kernowing
Has liked: 131 times
Been liked: 58 times
Post by kernowing »
If you highlight the two routes (Lft. click + Ctrl) then rt. click on one, you will get the option to join the selected routes. Away you go ;) Well it worked for me, hope it does for you. :)
2007 GL1800 Goldwing
Zumo 660LM
kernowing
Post by kernowing »
You posted that while I was checking that it worked :lol:
Zumo 660LM
