I edited a route this morning..and in the process ended up with the routes in 2 sections..when I highlight the first section of the route it doesn't highlight the whole route, only the first part. The same is true when I highlight the 2nd half of the route.
How do I combine the 2 halves of the route into one route?
Combining routes
- Has liked: 144 times
- Been liked: 21 times
- kernowing
- Has liked: 131 times
- Been liked: 58 times
Re: Combining routes
If you highlight the two routes (Lft. click + Ctrl) then rt. click on one, you will get the option to join the selected routes. Away you go Well it worked for me, hope it does for you.
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
- kernowing
You posted that while I was checking that it workedCollingsBob wrote: ↑Sun Feb 23, 2020 7:51 pm Got it!
https://support.garmin.com/en-GB/?faq=M ... uvcUzbV2-s
Zumo 660LM
Zumo 660LM
