New Garmin Zumo XT
- kernowing
- Has liked: 131 times
- Been liked: 58 times
Re: New Garmin Zumo XT
Specs show that it includes map updates :- https://buy.garmin.com/en-GB/GB/p/679804#specs
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
So what I am struggling to understand is why, on Axamax's earlier post, is the 595 £120 more expensive than the new XT
- Been liked: 1 time
No mention of the USB being USB 3 which is really too bad given how long it takes to load maps.
Sent from my SM-T813 using Tapatalk
Garmin went back to USB Mini because it is a more robust connector than either the USB micro or USB C.
If you look at Garmin's site the 595 is still at £549 under previous models. I expected the XT to come in at £550 to £600.
- Has liked: 106 times
- Been liked: 63 times
Updating its supplied mapping is via its built in Wi-Fi.RadioFlyer wrote: ↑Sat Mar 07, 2020 9:14 pm No mention of the USB being USB 3 which is really too bad given how long it takes to load maps.
Are you saying that it can't be done via USB? If so then another reason I would avoid.Oop North John wrote:Updating its supplied mapping is via its built in Wi-Fi.RadioFlyer wrote: ↑Sat Mar 07, 2020 9:14 pm No mention of the USB being USB 3 which is really too bad given how long it takes to load maps.
I see 'in the box' there's a data cable so sounds like there's still USB connection.RadioFlyer wrote: ↑Mon Mar 09, 2020 1:30 pmAre you saying that it can't be done via USB? If so then another reason I would avoid.Oop North John wrote:Updating its supplied mapping is via its built in Wi-Fi.RadioFlyer wrote: ↑Sat Mar 07, 2020 9:14 pm No mention of the USB being USB 3 which is really too bad given how long it takes to load maps.
Would be nice to see USB 3!
