I'm desperately searching for where I can select which dashboard I will use as I can in my Zumo 390.
Not found anything in the manual neither.
Anybody that can give me a hint here?
br Lars
Correct, works just like the 590 / 595. Just don't be surprised if you can't see ETA as an option, if, you're not navigating a route
And like the 590/595 the trip data fields are defined differently when navigating or not navigating.Oop North John wrote: ↑
Correct, works just like the 590 / 595. Just don't be surprised if you can't see ETA as an option, if, you're not navigating a route![]()
