Changing dashboard type (as in 390)?
larsras
Denmark
Post by larsras »
Hi
I'm desperately searching for where I can select which dashboard I will use as I can in my Zumo 390.
Not found anything in the manual neither.
Anybody that can give me a hint here? ;-)
br Lars
Has liked: 343 times
Been liked: 368 times
Re: Changing dashboard type (as in 390)?
Don't believe you can, Garmin played with dashboards for a while on some models but then removed them from later ones. What are you trying to achieve though as there are often other things you can do?
larsras
Denmark
Post by larsras »
Ok, that was kind of annoying. On my Zumo 390 i get more/less info fields depending on which layout I select.
The one I use right now, has in non navigation mode: Elevation, Speed, Direction and Time shown.
On the XT I only have two fields, which is: Speed, and one more selectable (pt. Time).
Ah that's not really a dashboard but Map tools that provide additional trip data fields. These are explained on page 12 of the manual.
Accessed by tapping the three dots bottom right then selecting Trip data.
Has liked: 105 times
Been liked: 61 times
sussamb wrote: Sun Apr 19, 2020 12:37 pm Ah that's not really a dashboard but Map tools that provide additional trip data fields. These are explained on page 12 of the manual.
Correct, works just like the 590 / 595. Just don't be surprised if you can't see ETA as an option, if, you're not navigating a route ;)
V-Tom
Has liked: 12 times
Been liked: 15 times
Post by V-Tom »
And like the 590/595 the trip data fields are defined differently when navigating or not navigating.
..Tom
