Zumo repair in UK
Zumo repair in UK
Hi, I was updating the zumo when it slipped and I think has broken a pin in the micro usb slot. Can I get this repaired in the uk.
- Site Admin
- Has liked: 423 times
- Been liked: 240 times
Re: Zumo repair in UK
If it's just the USB port then most electronics places would be able to repair it
Ok got usb sorted but it will not charge or come on through usb or cradle. The guy that repaired said either the battery has shorted or the voltage regulator on the motherboard. Is this toast or will garmin repair .
- Outsider
- Has liked: 2 times
- Been liked: 8 times
- Contact:
What does it do with the battery removed?
- Outsider
My occasional adventures: www.outsider-adventure.blogspot.co.uk
My other passion: www.droidbot07.blogspot.co.uk
- Outsider
- Contact:
Sounds like the main board then. There might be some input protection that may have limited the damage but you won’t know until you open it up.
I’d check with Garmin first, see if they’ll repair it.
- Outsider
- Outsider
- Contact:
Just thinking again, if it was only impact damage, it can’t have done too much damage to the internals. If the connector repair has been done correctly then that can only mean input protection has taken a hit (when the connections moved). If Garmin won’t touch it, don’t bin it...
- Outsider
I'm going to try to call garmin in Southampton tomorrow. Depending on the age of the unit they may swap for a recon unit at a price.
- Outsider
- Contact:
Let us know what happens. And good luck!
- Outsider
Bonus
called garmin. They are going send a new one free of charge and I send mine back. Big thumbs up to garmin UK.
