Zumo repair in UK
bald biker
Zumo repair in UK
Post by bald biker »
Hi, I was updating the zumo when it slipped and I think has broken a pin in the micro usb slot. Can I get this repaired in the uk.
Been liked: 266 times
Re: Zumo repair in UK
If it's just the USB port then most electronics places would be able to repair it
bald biker
Ok got usb sorted but it will not charge or come on through usb or cradle. The guy that repaired said either the battery has shorted or the voltage regulator on the motherboard. Is this toast or will garmin repair .
Outsider
Been liked: 8 times
Post by Outsider »
What does it do with the battery removed?
- Outsider
My occasional adventures: www.outsider-adventure.blogspot.co.uk
My other passion: www.droidbot07.blogspot.co.uk
bald biker
Nothing.😟
Outsider
Been liked: 8 times
Post by Outsider »
Sounds like the main board then. There might be some input protection that may have limited the damage but you won’t know until you open it up.
I’d check with Garmin first, see if they’ll repair it.
- Outsider
Outsider
Been liked: 8 times
Post by Outsider »
Just thinking again, if it was only impact damage, it can’t have done too much damage to the internals. If the connector repair has been done correctly then that can only mean input protection has taken a hit (when the connections moved). If Garmin won’t touch it, don’t bin it...
- Outsider
bald biker
I'm going to try to call garmin in Southampton tomorrow. Depending on the age of the unit they may swap for a recon unit at a price.
Outsider
Been liked: 8 times
Post by Outsider »
Let us know what happens. And good luck!
- Outsider
bald biker
Bonus 😁 called garmin. They are going send a new one free of charge and I send mine back. Big thumbs up to garmin UK.👍
