OSM Map a little slow
Andrew_XT
Italy
Post by Andrew_XT »
Hi to all
Building a route, I look that in my area (North of Italy) not all the street is present in Garmin Maps ( i have already Updated it).
For this reason i tryed to install the OSM Maps because i find in it those route.
All it works, but the maps and expecially the reserch of any location, is very slow respect in the other maps.
I installed the maps with Garmin Basecamp, and i understend that it was installed in the SD Card, Class U1.
Depend about the SD Card.
Any suggestion?
Thank you
Re: OSM Map a little slow
Card shouldn't be an issue, more likely just the map.
Vespamarc
Been liked: 14 times
Belgium
Post by Vespamarc »
If you download OSM maps, in that mapfile there is always a gmapsupp.img image, this file is for the sd card. Just drag and drop, and no installation from basecamp or mapinstall.
Andrew_XT
Italy
Post by Andrew_XT »
sussamb wrote: Tue Aug 18, 2020 6:03 am Card shouldn't be an issue, more likely just the map.
Thanl you
Andrew_XT
Italy
Post by Andrew_XT »
Vespamarc wrote: Tue Aug 18, 2020 7:48 am If you download OSM maps, in that mapfile there is always a gmapsupp.img image, this file is for the sd card. Just drag and drop, and no installation from basecamp or mapinstall.
The map i downloaded is a .exe file to install in Win10.
I use it also in Basecamp.
Vespamarc
Belgium
Post by Vespamarc »
Last line is for sd
Schermafbeelding 2020-08-18 om 12.01.24.png (101.18 KiB) Viewed 2933 times
Andrew_XT
Italy
Post by Andrew_XT »
Vespamarc wrote: Tue Aug 18, 2020 10:02 am Last line is for sd
Thank you
A little late - but also, make sure that you turn off the maps that Garmin provide. It will let you have all of them ticked in MyMaps, but it does weird things if they are (like navigate you in straight lines across open fields).
You will lose accurate timing information as the OSM maps do not have the speed limit information (or they didn't when I downloaded mine).
