route planner
r1ray
route planner
Post by r1ray »
Does anyone know of a better route planner than base camp? I just cannot get my head around it, i will even pay for one that is much easier to use
Thanks Ray
Has liked: 337 times
Been liked: 366 times
Re: route planner
Try reading https://www.newenglandriders.org/learn-basecamp/
BaseCamp is simple enough once you learn how to use it.
CollingsBob
Has liked: 144 times
Been liked: 21 times
Re: route planner
Post by CollingsBob »
r1ray wrote: Sun Oct 04, 2020 4:01 pm Does anyone know of a better route planner than base camp? I just cannot get my head around it, i will even pay for one that is much easier to use
Thanks Ray
I can help with real basic stuff to get you started..
Certified JB Welder
Has liked: 410 times
Been liked: 229 times
Re: route planner
I watched a load of [mention]Joby[/mention] which helped a lot
https://www.youtube.com/c/JosephByrne/videos
Has liked: 101 times
Been liked: 220 times
Re: route planner
CollingsBob wrote: Sun Oct 04, 2020 6:04 pm I can help with real basic stuff to get you started..
Ditto here. This forum and some of its reference materials get pretty in-depth and tedious. If you need basic, practical info to get started I'm your guy!
Dusty ST
Has liked: 13 times
Been liked: 10 times
Re: route planner
Post by Dusty ST »
I recommend doing all planning in My Route, particularly good to share around others using Tom Tom.
I heard it's got expensive recently though!
https://www.myrouteapp.com/en/home
r1ray
Re: route planner
Post by r1ray »
Hi Dusty
Thanks for that one. Just logged onto tom tom my drive and i already have the the route planning in (my drive) and covers everything
:D :lol:
