Does anyone know of a better route planner than base camp? I just cannot get my head around it, i will even pay for one that is much easier to use
Thanks Ray
route planner
Re: route planner
Try reading https://www.newenglandriders.org/learn-basecamp/
BaseCamp is simple enough once you learn how to use it.
CollingsBob
- Has liked: 149 times
- Been liked: 21 times
Re: route planner
I can help with real basic stuff to get you started..r1ray wrote: Sun Oct 04, 2020 4:01 pm Does anyone know of a better route planner than base camp? I just cannot get my head around it, i will even pay for one that is much easier to use
Thanks Ray
Certified JB Welder
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
Re: route planner
I watched a load of [mention]Joby[/mention] which helped a lot
https://www.youtube.com/c/JosephByrne/videos
- Has liked: 119 times
- Been liked: 267 times
Re: route planner
Ditto here. This forum and some of its reference materials get pretty in-depth and tedious. If you need basic, practical info to get started I'm your guy!
Re: route planner
I recommend doing all planning in My Route, particularly good to share around others using Tom Tom.
I heard it's got expensive recently though!
https://www.myrouteapp.com/en/home
Re: route planner
Hi Dusty
Thanks for that one. Just logged onto tom tom my drive and i already have the the route planning in (my drive) and covers everything
