Does the Motorcycle mount have a usb connection?
I'm getting one delivered on Friday, and I already have a 12v Socket installed on my motorbike, so it will be a lot easier just to plug the "cigarette lighter" in to the mount then to fiddle around with the car mount.
Zumo XT Motorcycle Mount
- Site Admin
- Has liked: 424 times
- Been liked: 245 times
Re: Zumo XT Motorcycle Mount
No it doesn't
Although you could easily wire power lead to whatever you need to to get it working
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
The MC mount just has 2 wires, red & black, as 'Stu' says put whatever termination or plug you need on the lead.Kermit The Frog wrote: ↑Wed Jan 06, 2021 3:45 pm Does the Motorcycle mount have a usb connection?
Well I'm using the cigarette lighter connection plugged into the usb on the xt, but I wish they had put a usb connector on the cradle
- simoncrewe
I think they avoid a USB on motorcycle mounts as they attract dirt/moisture & have vibration issues. Hence most mounts are hard wired & encapsulated.
Have you had any problems with the vibration connecting with the USB cable to unit to charge while riding?Kermit The Frog wrote: ↑Wed Jan 13, 2021 9:42 am Well I'm using the cigarette lighter connection plugged into the usb on the xt, but I wish they had put a usb connector on the cradle
Only had it on for the first time this morning (Amazon were being really stupid delivering it), but I had no problems this morning. We'll see how it goes tonight
