Zumo XT Motorcycle Mount
Kermit The Frog
Post by Kermit The Frog »
Does the Motorcycle mount have a usb connection?
I'm getting one delivered on Friday, and I already have a 12v Socket installed on my motorbike, so it will be a lot easier just to plug the "cigarette lighter" in to the mount then to fiddle around with the car mount.
Been liked: 266 times
Re: Zumo XT Motorcycle Mount
No it doesn't
Although you could easily wire power lead to whatever you need to to get it working
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
Kermit The Frog wrote: Wed Jan 06, 2021 3:45 pm Does the Motorcycle mount have a usb connection?
The MC mount just has 2 wires, red & black, as 'Stu' says put whatever termination or plug you need on the lead.
Kermit The Frog
Well I'm using the cigarette lighter connection plugged into the usb on the xt, but I wish they had put a usb connector on the cradle
simoncrewe
Has liked: 47 times
I think they avoid a USB on motorcycle mounts as they attract dirt/moisture & have vibration issues. Hence most mounts are hard wired & encapsulated.
me29
Post by me29 »
Kermit The Frog wrote: Wed Jan 13, 2021 9:42 am Well I'm using the cigarette lighter connection plugged into the usb on the xt, but I wish they had put a usb connector on the cradle
Have you had any problems with the vibration connecting with the USB cable to unit to charge while riding?
Kermit The Frog
Only had it on for the first time this morning (Amazon were being really stupid delivering it), but I had no problems this morning. We'll see how it goes tonight
