Hey, that looks like it will do the job. Where do you buy these please?
XT mount accidentally unlocking during ride
Re: XT mount accidentally unlocking during ride
Contact me on Messagener
https://www.facebook.com/me/
I will share to you the contact info
I placed a Mounting Pad (used with Zip Tie) and than ran a rubber band through the holes and around the back of the mount.
Utilitech # 0292685 I tried to attached a picture but It did not work I bought it at Lowes HW were the zip ties are
Good morning Andrew.
Your link goes straight to my Facebook page, not yours. I've sent you a PM
- simoncrewe
- Has liked: 46 times
- Been liked: 37 times
Run a tether to the rear of the unit with a stick on zip tie mount. This is what I did before I bought the Touratech locking mount. Don't waste your money on the 'Zumo Lock' it only blocks the release catch, it does not secure the unit itself.SteveA wrote: ↑Fri Feb 05, 2021 5:51 pm This hasn't happened to me yet but each time I ride with the XT in the mount I'm getting 'undue anxiety'.
If the XT was to pop out of the mount it would probably be destroyed or ran over by a following vehicle etc.
Has anyone a simple solution to prevent this happening or am I maybe worried about something that won't happen?
thanks - I cover my with my Hemet when in a restaurant and take it off when I'm in a hotel
- Been liked: 6 times
- Contact:
My solution, among all possible, using one of the rear fixing screws; can be mounted on one of the 4 corners of the GPS:
On s'en fout de connaitre la vérité, l'essentiel c'est d'avoir raison (Me Eric Dupond-Moretti)
It doesn't matter what the truth is, the important thing is to be right (French Lawyer Eric Dupond-Moretti
Fun is not a straight line !!!!
Great idea. Any idea if it might compromise the water proofing?communicator wrote: ↑Thu Feb 11, 2021 11:27 am My solution, among all possible, using one of the rear fixing screws; can be mounted on one of the 4 corners of the GPS:
