cover for connections on the mount
warfelron
Post by warfelron »
I have been looking for a cover, to cover the GPS connection when I take the GPS off when I'm staying at a hotel. I don't like leaving those connection pins exposed to the weather. I just call GArmin ... They dont make one. They told me most people keep thier bike in a garage. I said I do to but i also ride mine for overnight trips and take off the GPS at night (or someone will for me) and did not want the pin connection exposed to the weather.
Re: cover for connections on the mount
Something like the cover here: https://www.zumolock.com/index.php/en/p ... dle-detail maybe?
Hati
Been liked: 15 times
Australia
Post by Hati »
warfelron wrote: Mon Feb 08, 2021 10:05 pmI don't like leaving those connection pins exposed to the weather.
Where is your rubber connector cover?
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
You should be able to buy the larger rubber connecter cover on eBay separate from the lock.
warfelron
Post by warfelron »
Thanks great idea anyone send me link to connect tor cover
warfelron wrote: Tue Feb 09, 2021 9:35 am Thanks great idea anyone send me link to connect tor cover
https://www.ebay.co.uk/itm/Garmin-Zumo- ... SwxUFfjrST
€24 postage to the USA.
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
warfelron wrote: Mon Feb 08, 2021 10:05 pm I have been looking for a cover, to cover the GPS connection when I take the GPS off when I'm staying at a hotel. I don't like leaving those connection pins exposed to the weather. I just call GArmin ... They dont make one. They told me most people keep thier bike in a garage. I said I do to but i also ride mine for overnight trips and take off the GPS at night (or someone will for me) and did not want the pin connection exposed to the weather.
Have you lost the original power plug cover that comes on the lead?
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
I read somewhere that the supplied rubber cover can cause pin damage. Could be wrong though 😅🤣, I often am.
This thread is worth a read.
viewtopic.php?f=48&t=816
Breezly
Has liked: 22 times
Been liked: 33 times
Post by Breezly »
Something like these?
I purchased these from a gentleman, Berto Klein, on the Dutch Facebook group: Garmin Zumo groep
Been liked: 265 times
If you search online you can find the files to make them with a 3d printer
I had two made by a friend and they are really good
