595 Questions
Has liked: 104 times
Been liked: 221 times
595 Questions
Hello all. Recently signed up as I'm trying with little-to-no success to switch from a nuvi I've been using for a long time to a Zumo 595. I've been reading & searching for about 2 weeks now and cannot find what I'm looking for. So here goes:
Is it possible to "clean up" the Zumo display? I find that often it's so cluttered with fuel station & restaurant icons that I often can't see the roads underneath them.
Has liked: 344 times
Been liked: 369 times
Re: 595 Questions
You can switch off the Up ahead feature in Map Layers if you find them distracting.
Re: 595 Questions
Ah, got it! Made me realize the differences in terminology from my old nuvi and what each thing does. I hate user manuals like this- tells you how to do things but not what that thing is or does.
Now I'm trying to add an additional point to a route I'm running. I get "Touch the Screen" and when I do it says "Pick a Valid Point". Somehow I was able to add a point one time but I can't repeat it. I think I figured out from the one time it worked for me that the user's manual is totally screwy on this- I see nothing of what it says I will see.
patrickg450
Re: 595 Questions
Post by patrickg450 »
sussamb wrote: Mon Jun 18, 2018 3:41 pm You can switch off the Up ahead feature in Map Layers if you find them distracting.
same problem, I was not able to find the setting.......
got some info to help me find it.
Re: 595 Questions
Should be in Settings, Map & Vehicles, Map layers
patrickg450
Re: 595 Questions
I found it, I must have gone past it 3 or 4 times.
Thanks for the help.
PG
