All the program is updated
Garmin Express now is 7.5 , 7.6 versios was removed from Garmin dowload site.
I have called the Garmin support center, they told me the Garmin Software departement is working on Basecamp to fix this problem with Zumo XT.
They don't know how many time need. They told me "Remeber Basacamp is a free software"
Easy solution to install City Navigator maps on PC/Mac
Re: Easy solution to install City Navigator maps on PC/Mac
Well these were the changelogs for 7.6 and it was meant to fix it, a number of Zumo XT users reported it had, guess it didn't work for all.
Implemented the ability for newer devices to install maps to the computer.
Resolved an issue with Express displaying a blank window when signing into Garmin Connect for select users.
Other bug fixes and improvements
@sussamb - You're right, the main problem from before, maps couldn't be installed on PC/Mac, was corrected, BUT - those maps wouldn't be unlocked and so they are unusable on the computer! Garmin screwed it again and after a week or so they pulled back GE 7.6.0.0. and left behind many angry and confused users, because the 'pc-maps-are-not-unlocked' problem affects now more devices than the Zumo XT...
Sorry to say - but was Garmin had made with the Zumo XT is a real disaster now - a brilliant piece of hardware, but the software around and also the firmware are way behind (to be friendly). And all started with the firmware-merge with the new Garmin Tread - before, there was firmware 2.90 and all (or almost all) was working fine and the baddest errors where cleaned out and this was really the best motorbike-gps ever!
Then came the Garmin Tread and the merge with this series and with this all the 'new' firmware 5.90 and the disaster began...
One example - we got the possibility to add a rear-view-camera, which makes real sense on a motorcycle!
Bye, Robert
- nehpetsthegrey
- Has liked: 2 times
- Been liked: 3 times
Hail Rofor and those of you who understand the work around and all thing Garmanical. From a numpty like me that may not be of much value but you certainly helped me. Many thanks . My little file card is now a treasured item. If only I understood what you were talking about. AWESOME
i contacted garmin about it a month ago and they updated express to 7.6 and it worked for me.
iv just started express up again and its wanting me to update to 7.7.1.0. i cant test it out has my unit has been sent back to garmin for replacment due to ghosting.
I've upgraded to v7.7.0.0 on my Mac and was able to copy down the City Navigator map just fine (and it's not locked). Looks like they finally solved this issue.
For safety, don't 'throw away' your fake Zumo XT sticks/cards!
At least with the Windows versions of Garmin Express there seem to be some troubles anyway:
- with 7.7.0.0. there were some problems with unlocking the map on pc, and
with 7.7.1.0. there are some reports, that users are unable to install the maps to another location as the from Garmin suggested one
Bye, Robert
Seems this problem is back. I just bought a Zumo XT and couldn't download the Maps to my Mac. Using GE 7.8 and you try to download and GE just sits there doing nothing. I tried the hack at the top and seems to have worked fine so many thanks for that. Will report it to Garmin in case it does any good.
- Has liked: 349 times
- Been liked: 744 times
Welcome Rob
The current version of Garmin Express is 7.8.1.0
Check you have the latest version, there have been a couple of updates recently.
Also check that Basecamp is not using the USB port. They sometimes interfere with each other - probably because they are trying to access the same data from the same device. If necessary USE CTRL ALT DEL on your PC to open up task manager and kill the application that may still be running in the background. Then try again.
Let us know if that helps please !!
Hi - thanks for the quick reply. I'm on a Mac and not a PC. I have the latest Mac version of GE installed which is 7.8.0.0 but there was no way I could get the maps to download until I tried the hack which worked straight away. I tried the download without BaseCamp running
