I have read the Montana mount is better and more durable and wondered if it works with the Zumo xt?
link to mount - https://buy.garmin.com/en-GB/GB/p/pn/01 ... 03#devices
Is anyone using this or know?
Thank you David
does the montana bike mount fit zumo?
- Has liked: 2 times
- simoncrewe
- Has liked: 46 times
- Been liked: 37 times
Re: does the montana bike mount fit zumo?
Totally different mount, will not work with the XT.DAVIDWILSON wrote: ↑Thu Nov 04, 2021 2:24 pm I have read the Montana mount is better and more durable and wondered if it works with the Zumo xt?
Thank you David
