does the montana bike mount fit zumo?
DAVIDWILSON
Post by DAVIDWILSON »
I have read the Montana mount is better and more durable and wondered if it works with the Zumo xt?
link to mount - https://buy.garmin.com/en-GB/GB/p/pn/01 ... 03#devices
Is anyone using this or know?
Thank you David
Fxwheels
Has liked: 26 times
Been liked: 29 times
Re: does the montana bike mount fit zumo?
Post by Fxwheels »
David, Montana has the connectors on the bottom of the unit whereas XT in the back. I don't see how it will work...
simoncrewe
Has liked: 46 times
Been liked: 37 times
Post by simoncrewe »
DAVIDWILSON wrote: Thu Nov 04, 2021 2:24 pm I have read the Montana mount is better and more durable and wondered if it works with the Zumo xt?
Thank you David
Totally different mount, will not work with the XT.
