XT mount accidentally unlocking during ride
SteveA
Has liked: 22 times
Been liked: 3 times
Re: XT mount accidentally unlocking during ride
Post by SteveA »
Andrew_XT wrote: Mon Feb 08, 2021 5:29 pm
colirv wrote: Mon Feb 08, 2021 9:58 am Click "Post reply" then click "Attachments" tab at bottom. You can then drag an image into your message box.
Hey, that looks like it will do the job. Where do you buy these please?
Andrew_XT
Italy
Post by Andrew_XT »
SteveA wrote: Mon Feb 08, 2021 6:58 pm
Contact me on Messagener
https://www.facebook.com/me/
I will share to you the contact info
warfelron
Post by warfelron »
I placed a Mounting Pad (used with Zip Tie) and than ran a rubber band through the holes and around the back of the mount.
Utilitech # 0292685 I tried to attached a picture but It did not work I bought it at Lowes HW were the zip ties are
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
warfelron wrote: Mon Feb 08, 2021 9:58 pm I placed a Mounting Pad (used with Zip Tie) and than ran a rubber band through the holes and around the back of the mount.
Is it these?
https://www.lowes.com/pd/Utilitech-10-P ... s/50005766
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
Andrew_XT wrote: Mon Feb 08, 2021 7:49 pm
Good morning Andrew.
Your link goes straight to my Facebook page, not yours. I've sent you a PM 👍
warfelron
Post by warfelron »
Yes and use a hair (pony tail) rubber band
simoncrewe
Has liked: 46 times
Been liked: 37 times
Post by simoncrewe »
SteveA wrote: Fri Feb 05, 2021 5:51 pm This hasn't happened to me yet but each time I ride with the XT in the mount I'm getting 'undue anxiety'.
If the XT was to pop out of the mount it would probably be destroyed or ran over by a following vehicle etc.
Has anyone a simple solution to prevent this happening or am I maybe worried about something that won't happen?
Run a tether to the rear of the unit with a stick on zip tie mount. This is what I did before I bought the Touratech locking mount. Don't waste your money on the 'Zumo Lock' it only blocks the release catch, it does not secure the unit itself.
warfelron
Post by warfelron »
thanks - I cover my with my Hemet when in a restaurant and take it off when I'm in a hotel
communicator
Been liked: 6 times
France
Post by communicator »
My solution, among all possible, using one of the rear fixing screws; can be mounted on one of the 4 corners of the GPS:
On s'en fout de connaitre la vérité, l'essentiel c'est d'avoir raison (Me Eric Dupond-Moretti)
It doesn't matter what the truth is, the important thing is to be right (French Lawyer Eric Dupond-Moretti
Fun is not a straight line !!!!
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
communicator wrote: Thu Feb 11, 2021 11:27 am My solution, among all possible, using one of the rear fixing screws; can be mounted on one of the 4 corners of the GPS:
Great idea. Any idea if it might compromise the water proofing?
