Easy solution to install City Navigator maps on PC/Mac
ray6576
Been liked: 9 times
Re: Easy solution to install City Navigator maps on PC/Mac
Post by ray6576 »
I upgraded my Garmin express and had no problem updating my maps for Basecamp. I check the map information and Basecamp reports it as unlocked at least the Mac version in the US seems to be doing what it should.
Temporary solution for this - from the folder .System/Maps on the Zumo XT copy the file 'D6210130A.gma' to 'c:\Users\(username)\AppData\Roaming\Garmin\Maps\ this should unlock the map in BaseCamp...
Alternatively you could copy the .gma to 'c:\ProgramData\Garmin\Maps\', this also should work....
Triplog
Has liked: 22 times
Been liked: 6 times
Post by Triplog »
Just done on mine, map already unlocked on installation. Thanks for this ingenious solution!
I don't have a D6210130A.gma file in .System/Maps on my Zumo XT. There are 7 other .gma files though. Is this file map specific? If so, a way to identify the file to unlock City Navigator North America NT 2022.1 and its Foursquare and Parkopedia counterparts would be appreciated.
Andrew_XT
Italy
Post by Andrew_XT »
Today i have updated the Zumo with 2022.1 map.
After with Garmin express i have install the map on the PC but still the problem "Map Blocked"
I have try coping the file .GMA inthe PC folder, but doesn't work
More solution?
Work with the map on Zumo is very very slow
Thanks
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
Contact Garmin support, like I have & insist they sort the problem out. We should not be doing their job for them.
Did you update Express first? The latest version is meant to have resolved this?
Rofor
Has liked: 182 times
Been liked: 83 times
Austria
Post by Rofor »
Peobody wrote: Thu Jun 03, 2021 8:05 pm I don't have a D6210130A.gma file in .System/Maps on my Zumo XT. There are 7 other .gma files though. Is this file map specific? If so, a way to identify the file to unlock City Navigator North America NT 2022.1 and its Foursquare and Parkopedia counterparts would be appreciated.
Yes, they are map-specific - try to identify it by the date of the file, this should be the safest variant! I didn't know, if the same counts for the us version 2022.10 of CN, but for the european CN it is D6210180A.gma...
Bye, Robert :)
Rofor
Austria
Post by Rofor »
sussamb wrote: Sat Jun 12, 2021 5:58 am Did you update Express first? The latest version is meant to have resolved this?
You're sure? As far as i know, Garmin Express 7.6.0.0. has caused all this troubles (not unlocking maps, devices not found and so on)!?
My solution for the problems was to uninstall GE 7.6.0.0. (do NOT tick 'delete all files belonging to Garmin Express'!!), install 'old' Garmin Express 7.5.0.0., install CN 2022.10 for BaseCamp with 'fake-Zumo-XT' and install CN 2022.10 on the unit with real Zumo XT - no problems at all!
Bye, Robert :)
simoncrewe
Has liked: 47 times
Garmin have deleted GE 7.6 & reverted to 7.5 as the new software did not work & was loading locked maps to Basecamp.
I currently have a case open with Garmin support to hopefully get this resolved.
It does however, seem to be unique to the Zumo XT.
