3D AM Adapter
purds
Re: 3D AM Adapter
Post by purds »
Sounds like a problem with the pins not making contact properly to me.
Connecting via the USB port goes straight into unit socket and doesn't use the pins - this works ok.
You know you have voltage across the pins but the power doesn't reach the Zumo - so likely the pins aren't connecting properly I would guess.
Been liked: 266 times
Re: 3D AM Adapter
purds wrote: Tue May 09, 2023 4:19 pm Sounds like a problem with the pins not making contact properly to me.
I'm not so sure as the zumo is turning on when the bike is powered up
When I was having issues it was the charge controller not putting enough voltage out but @Don has replaced that
One thing I did notice on mine though is when it stopped charging if I turned the screen brightness down it would start to charge again
Have you also tried to start the bike then fit the zumo? as on BMW bike there is a short interruption of the power on all auxiliaries when you hit the starter
purds
Re: 3D AM Adapter
Post by purds »
:cry:
Stu wrote: Tue May 09, 2023 6:58 pm
Good point 🙄
Re: 3D AM Adapter
purds wrote: Tue May 09, 2023 7:12 pm :cry:
Good point 🙄
Don't write it off though as it might just be enough to turn it on and not charge it
Don
Re: 3D AM Adapter
Post by Don »
Thanks Purds and Stu, I will persevere with the unit and try what you suggest and hopefully the unit will start charging. Kind Regards to you both for your help.
purds
Re: 3D AM Adapter
Post by purds »
Good luck Don - hope you sort it
