Saving routes
colirv
Has liked: 54 times
Been liked: 43 times
Saving routes
Post by colirv »
Basecamp allows me to plan several route in advance and transfer them to the XT. If I'm on holiday without a computer is there any way of planning several routes in advance on the XT itself and saving them there?
Colin
BMW R1250RS
https://www.namrider.com
Milu23771
Been liked: 8 times
Italy
Re: Saving routes
Post by Milu23771 »
There is a route planner on the device, but in my opinion it is not very practical. Alternatively you can create routes on your smartphone, for example with Osmand or with My Route App and share them with the Drive application, which will transfer them to the Zumo, adding them to the saved trips
colirv
Has liked: 54 times
Re: Saving routes
Post by colirv »
Doh! I'd completely missed why Route Planner was so named. Flawed but of some use. I'm indebted to you!
Colin
BMW R1250RS
